주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP EliteBook 840 G3 수리 정보입니다. 이 Hewlett-Packard 노트북은 기업용으로 설계되었습니다.
Booting device not found 3FO error
All of the sudden my pc is not opening it is saying booting device is not found... I tried to get in to bios and try to fix it but it's asking me bios administration password and I don't know it.
Am a student and I need help as soon as you can, exam is around the corner.
Thank you for your time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
For starters follow the steps below to run HP Diagnostics.
  • Restart the computer.
  • As the computer boots, press the ESC key when the HP Splash Screen appears.
  • When the Startup menu appears, press F2 to enter System Diagnostics.
  • Run the Hard Disk Test in System Diagnostics
  • Best to test everything but especially the hard drive.
Let us know what you get. You may be interesed in the discussion below.
It is possible that the hard drive is defective or corrupted.
Look on the web. There are several bootable USB flash drive diagnostics, etc. to check and even repair your non-booting hard drive.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Hi @aactech,
Don't know HP that well but can you enter diagnostics without knowing the admin (BIOS) password?
Cheers
의
Hi @jayeff Happy New Year!
Good question.
What I can tell you is that at power on-
Pressing<F2>takes you directly to System Diagnostics.
Pressing <F10> takes you directly to the BIOS Setup screen.
Pressing <ESC> takes you to the Menu Screen where <F2> takes you to System Diagnostics or <F10> to the BIOS setup page, <F7> takes you to Spare Key explained here:
https://h30434.www3.hp.com/t5/Notebooks-...
I have never personally used nor recommended that password to any clients as it causes more problems than it is worth.
So to answer your question I don't know for sure.
의
@aactech
Happy New Year to you too. ;-)
Thanks for that.
Cheers
의
댓글 달기
Well try these fix
  1. Turn off the computer and wait five seconds.
  2. Press the power button to start the computer and repeatedly press the f10 key to enter the BIOS setup menu.
  3. On the BIOS Setup screen, press f9 to select and load the BIOS Setup Default settings.
  4. Press f10 to Save and Exit.
For more you should read this: https://support.hp.com/in-en/document/is...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
F9 isn't responding
의
댓글 달기
답변을 추가하세요
Ayub Ali 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 24
전체 시간: 2,720
