주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 플래그십 폰의 대형 모델. 2018년 3월 출시.
Why does my phone keep restarting?
At first it only restarted a couple of seconds after the screen was off. I tried to fix it by trying to update my phone, restarting it manually, and deleting some apps. But now it just turns off randomly every couple of minutes. It just started today, u don't know what to do.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
@gus_gush since it appears to become more frequent, you want to start off with a new battery. If nothing else it will provide you with a known-well starting point
Samsung Galaxy S9 Plus 배터리 교체
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @gus_gush
Does it do this with the charger connected?
Things to try and see if they resolve the problem:
  • Wipe the cache partition and check if that resolves the problem.
  • Try starting the phone in safe mode and check if it works OK. If it does then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app one by one and then test the phone in normal mode between each uninstall to see if the phone works OK or not. When it does work OK then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and it wasn't pre-instaled on the phone when you first got it.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Its not doing it when my phone is on the charger
@gus_gush
Then I suggest that the battery is replaced as recommended above by @oldturkey03
댓글 달기
답변을 추가하세요
Gustavo A Reyna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 1,246
