주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMachines ET1831-05는 eMachines에서 생산한 보급형 데스크톱 시스템입니다.
Green power Light keeps blinking
Green power Light keep blinking
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Press and hold the power button operated for >10 seconds and then release to ensure that the PC has fully shutdown in case it is in a sleep or hibernate state.
Once it has shut down try turning it on and check if it starts OK
If it doesn't start and boot into the OS then try a power refresh and check if that resolves the problem.
  • Turn off the PC and then disconnect the power to the PSU.
  • Open the PC and remove the coin cell RTC battery from the motherboard. (Once the battery is out, check its voltage. If it is <2.5VDC, replace it. The battery model number is stamped on the battery itself - CR2032 perhaps).
  • Press and hold the Power button for a full 30 seconds and then release it.
  • Reinsert the RTC battery into the battery holder on the motherboard (remember its orientation, usually +ve on top as marked on the battery)
  • Reassemble the PC, reconnect the power to the PSU and turn it on and check it it works OK.
If it turns on OK there may be a message stating that the time and date are incorrect. This is normal as the BIOS has been reset. Once the D&T have been corrected the message won't appear the next time that the PC is started.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanx I'll try getting another battery
의 공유
댓글 달기
답변을 추가하세요
ml3748915 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 563
