주요 콘텐츠로 건너뛰기
Battery charging error Deebot Ozmo 950
My Deebot Ozmo 950 suddenly stopped charging the battery and tells, teh battery is empty. I removed the battery, actually it functions well, I charged it with an external charger, and placed it back, same issue. Can you please advise!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
I'm unfortunately in the same situation, I have read in some obscure forums that when it happens for the 950 might be the motherboard, but I have no means of testing it
Hey there! i have the same problem and wanted to ask what charger you used to charge the battery outside of the device, thanks!
댓글 달기
답변 2개
@jozsefkazs48209 @welsonjr before digging into the motherboard, I would consider this an error of the battery controller board. Remember that these are smart batteries. They usually "report" the state of charge etc to the charge controller. Those parts "talk" to each other (smarter than some people right ;-). I would at least try a new battery to see if that resolves it. There are no schematic for the battery controller, so troubleshooting would be difficult.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I tried the new battery, however the problem is not solved
댓글 달기
the 950 has a pile of charging circuitry on the motherboard near the tiny plug where the power comes in from the 2 metal fet, but on the underside of that socket.
The mosfet q10 (labled NL9345 but not a part number i can locate) appears to be a p-mosfet in charge of switching power to the battery for charging. it needs 14v on its gate (pin 4), which is controlled by a pile of transistors / biased by a few resistor networks.......
Check gate pin voltage of that mosfet, if its around 20v / loosely aligned with input voltage then thats why its not charging / why signal isnt reaching mosfet. in my case it was caused by r89 being opened. There are 3 resistors next to that mosfet - r97 > 57 ohms, r88 -> 57 ohms, r89 -> 2.2kohms, confirm those are correct values. if they look right and you still not getting right voltage at mosfet gate, then possibly something else around that area of the board has gone bad(he tiny transistors around there? the diodes or the mosfet itself or one of the many fuses between the power in and the battery)
ultimately the mosfet pin 1-3 are the input power (20v) from the base station, pin 4 is gate and should be ~14v, pin 5-8 is battery voltage (~12v if battery is low, ~16v if battery is fully charged).
if mosfet is bad, try looking for something that will fit the "outer pads, be much easier to solder and to buy.... (sorry i dont have a recommended part but above voltages should give you an idea)
remember.... attempt to fix at your own risks, batteries are dangerous etc standard disclaimers
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
József Kazsoki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 40
전체 시간: 912
