주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 질문 전체 보기
Leaking on left side of radiator
Where is the leak coming from .I change out filler part and I still see fluid
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@ajmendez1975 could be a leaking hose or a leaking radiator. We really need to see where you are looking it and see if we can guide you further. The best test would be a pressure test. Not sure where you are located so it'll be kind of useless to tell you a store where you can get them from. Just do an online search for Radiator Pressure tester and see if that is something you want to invest in. If not, some radiator places will do this for you, but may charge you.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Andrew Mendez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 75
