주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
두 바퀴로 움직이는 사람의 힘으로 가는 운송 수단입니다. 보유한 자전거를 검색하거나, 특정 부품을 찾거나, 관련 페이지 섹션에서 문제해결 위키를 탐색할지 결정하세요.
Frozen brake lines from rain
How do I keep brake lines from freezing? I have a Trek 7500 that has brake lines that freeze if water gets in the lines and temp drops below freezing. Have put teflon based lubricant on ends, put in warm basement, and they still freeze if all water is not out of lines. Help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 2개
선택된 해법
This problem is somewhat counter intuitive solved by using the brakes more than nessesary. You should use the brakes so that they tear down the ice on the rim surface. As the rims are icey the brake performance are poor and therefore not stopping the bike. But it does come with a bit of speed penalty, so it is best to clean the surfaces by breaking at select places on the path you are riding. Downwards is of course a good place to break (even if you doesnt have to lower your speed) and you can pedal as a counter act to the resistant the braking cause. Apply the break force with just the right amount to tear the ice down without stopping the bike. The ice tears down by scratching from the brake pads but also from heat coming from the friction between pad and icey rim. On the flats a gentle brake force for a while can reduce the ice significantly. Do not use any lube or similar. Clean the rims with alcohol or equivalent and use the best brake pads you can find. The pads are not overly expensive compared to the crusial job they are supposed to do, so go for the best!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Shahid,
Lubricate with antifreeze, let it run right down the cable. Or replace the cables.altogether.
Frank
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Shahid Raki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 1,680
