주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG VX5200은 외부 안테나, 32 MB 내장 메모리, 1000 mAh 리튬 이온(Li-ion) 배터리를 탑재한 CDMA 폴더폰입니다.
SIM card slot location?
Where is the slot for a SIM card located on my LG VX5200? Is there one? If not, what do I need to do to make the phone able to recei
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
If I don't see were to place my sim card what should I do to receive calls
의
Per my previous email. RTFM. See above.
의
@hassangabr19854 just as explained in the answers below :-) there isn't one.
의
댓글 달기
답변 2개
가장 유용한 답변
Hi Tess,
That particular phone was made pretty much exclusively for Verizon, and didn't come with a SIM card slot, since it only works on Verizon's CDMA network. It wasn't until the iPhone 5 that iPhones on Verizon started using SIM cards, and it's about that time frame that other phones that ran on Verizon also started using SIM cards.
Unfortunately, the phone does not support 4G networks so Verizon is not going to let you activate it on their network; they've phased out their older 2G technology and 3G is on its way out as well. So unless you can find another carrier that still supports the CDMA network, that phone is pretty much going to be a pretty brick.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@tess85230 is a CDMA phone that does not use a SIM card. You will need a provider (used to be Verizon) that still supports your phone to see what needs to be done to get it activated. Check this Wiki for more info on your phone. LG VX5200 Troubleshooting
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tess 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 1,181
