주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Blackscreen with blue dots when booting - RESOLVED
So this morning i turned my pc and worked perfectly but then my pc got so loud for some reason my screen turned black and then i turned my pc off by pressing the boot button on my pc after this i get a Blackscreen with blue dots.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개
I did happen before but worked fine once i restarted
Secure bios was off if that helps
Hi @redmoka65383,
What is the make and model number of the motherboard and GPU card?
Can you try another monitor (TV perhaps if GPU has HDMI output) and check if the same problem occurs?
Motherboard- Nzxt N7 B550 amd
CPU - Ryzen 7 3800x
I will try on my tv and i do not know the model numbers
Bios work perfectly
댓글 2개 더보기
댓글 달기
답변 2개
선택된 해법
Fix FOUND TURN ON SECURE BOOT
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
and how do i do this exactly?
nvm its in the bios
I found a solution, Take all of your Pc cables off, start your pc without cables, then wait 10 seconds and press the start button for 10 seconds till it takes all the extra energy out, plug in all of your cables back and turn your pc on.
Thanks Zett had this problem as well and this worked for me not sure why it worked but it did!
댓글 달기
가장 유용한 답변
Hi @redmoka65383
Here's the user manual for the motherboard.
Turn on the PC and check if any of the POST Leds are on. They will tell you if there's a CPU, Memory, GPU or HDD/SSD problem. See p.38 of the manual for their location on the motherboard.
It may be that the motherboard is not passing POST (power on self test) on startup.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@redmoka65383
Question to ask is why was it turned off if you didn't do it. was there an update or something?
댓글 달기
답변을 추가하세요
RedMoka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 28
전체 시간: 4,362
