주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ideapad 5-15ITL05 노트북 - 모델 유형 82FG. 2021년 10월에 출시된 이 노트북은 태블릿으로도 사용할 수 있는 터치 스크린을 탑재하고 있습니다.
No Backlight after Water Damage
이미지
이미지
이미지
Working on this laptop for a friend. Has some minor water damage mostly from the right side (nearest display cable connector on mboard).
Assumed the fuse FG3301 for the backlight was blown but it's OK. what else should I check?
Update (05/07/23)
이미지
이미지
이미지
이미지
이미지
이미지
I may get back to this repair later; friend is currently using the laptop with an external hdmi display since the backlight is the only known issue after water damage.
Additional info: the UL indicator label on the board reads
"HSB J
MV-4 E89382
94v-0"
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 12개
@isaiahneumann what model is the motherboard? have you checked the display connector? What voltage do you get on there? It could be any component with the backlight circuit. You'd have to trace it to see where the power starts/stops. You did not tell us if the fuse was good or not.
의
Board is "MV-4 94V-0".
Fuse was good.
Not sure which pins to check on display connector. Image and touchscreen work fine.
의
@isaiahneumann do you get voltage at the fuse on both sides, if you do add photos of the lcd connector and the back of the board and also the connector on the screen itself
의
@tech_ni
I only checked the fuse with the mboard entirely removed and disconnected.
의
@isaiahneumann double check on that number. I would have expected a LCFC board for the IdeaPAd 5. something like a NM-D031 Even better. Post some good pictures of your board with your QUESTION. That way we can see what you see. 기존 질문에 이미지 추가하기
의
댓글 7개 더보기
댓글 달기
답변 1개
선택된 해법
@isaiahneumann you have a corroded JEDP connector. You want to remove that cable and clean the connector with some high grade isopropyl alcohol. The first 4 contacts (top of your connector picture0 are for the backlight. They look pretty gnarly. You may need a new connector. Remove the cable, clean the connector and post some "after" images. Do not try to power on your board etc. since you may just cause more damage.
Post some good pictures of your board with your QUESTION. That way we can see what you see. 기존 질문에 이미지 추가하기 You can only add images to your Question which you must edit or to Answers. You can not add those as comments. Those do get lost....
At this point I would probably advise you to clean the complete board with some isopropyl alcohol. Nothing less than 90%. Preferably higher percentage. For as long as your board is not cleaned and you still have corrosion on connectors etc. no proper diagnostics can be accomplished.
이미지
Update (05/08/23)
@isaiahneumann here is the pinout for the connector
이미지
Since I am pretty confident that this is a NM-D211 board, here is the schematic for it Lenovo Air 15ITL 202 LCFC NM D211 PDF Hopefully your board survived since your cable seems to have taken the damage.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
@isaiahneumann your cable is toast :-) Contact 1-4 is for the backlight.
의
댓글 달기
답변을 추가하세요
Isaiah Neumann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 39
전체 시간: 2,089
