주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eighth generation of the Honda Civic.
Why does my horn not work?
My horn isn't working, and I have already checked the fuses
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@mbeaver your car's horn is behind the left side of the front bumper. Since you already check the fuse you want to check the horn next. Uswe a test light or a multimeter and connect the red probe to the positive wire on the horn. See if you get power when somebody activates the horn button. If yes you know it's your horn that need replacing. If no, check the horn relay which is located in the under the dash fuse/relay box
이미지
. If the relay is okay as well, it'll be time to check the horn switch. This should help you with all of this Honda Horn Repair
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mbeaver 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 1,221
