주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Blank screen/No signal
Built a PC. Everything shows it is running. The screen is npt connecting to anything. I have tried different monitors and different setups, different hard drives. No BiOS or anything comes up.
ASUS Prime Z590-P WiFi motherboard
Intel Core i7 11700F processor
GTX PCIe 730 Graphics card
CORSAIR DDR4 16GB RAM
I have reset CMOS. I have taken everything out.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @familyfun37946,
Is the 16GB memory, 2 modules i.e. 2 x 8GB or one 16GB module? Depending on number of memory modules have you installed them as per p.1-5 of the user manual?
The PC may not be passing POST (power on self test)
Try connecting a system speaker (example only) to the speaker pins on the System Panel connector on the motherboard (see p.1-20 of the manual for location of header and speaker pins) and check for any beep error codes (see beep code table on p.2-19).
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
They are two different sticks. They are seated in properly and everything. They even light up.
I will try the speaker test. It did not come with one, so I will have to get one. Thanks!
댓글 달기
답변을 추가하세요
Dreki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 4
전체 시간: 92
