주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Computer crashes to a blank green screen.
I’ve recently built my first pc and for the 1st day it was running great. Yesterday and today hasn’t been the same. After only a few minutes of running the pc will crash in to a blank green screen. Any tips? Anyone else ever have this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi @koithyboi,
What is the make and model number of the motherboard and the GPU card?
Try disconnecting the SSD (HDD?) and check if you can get into BIOS OK with a display.
Have you checked the monitor's working OK i.e. can you view the OSD menus?
댓글 달기
답변 1개
What operating system is it running on?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Was running windows 10 when it started. Upgraded to windows 11 only for it to crash more often
It could be a bios issue or corrupted files, maybe you should upgrade your drivers, it could be a monitor issue too
댓글 달기
답변을 추가하세요
koithyboi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 64
