주요 콘텐츠로 건너뛰기
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 질문 전체 보기
Suddenly monitor shows no signal RTX 2070s
I have a amd razen 5 pc
With asus rtx 2070s gpu
And asus monitor
Suddenly my pc off and when I turned it on monitor shows no display signal i try my monitor on other pc it works , it is from pc and also i rty all cables hdmi and diplay cables
What can i do
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@abolaila What are your full PC specs?
댓글 달기
답변 1개
Personally, I'd do the below:
- Physically disconnect and reconnect cables from BOTH sides and ensure they're plugged in securely.
- Swap the cables, if possible, and see if the issue follows the cable (which would indicate the cable is bad).
- Try another monitor on the same PC, with the same cable, in the same port.
Are you getting an image at all on the custom machine you built with ANY combination of monitors/cables/connections?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abo Laila 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 51
