주요 콘텐츠로 건너뛰기
will this screen fit?
will IF150-001 fit on an iBook g4 1064 mhz machine?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
That's the complete assembly from a G3 iBook which won't fit. The LCD inside it 'should fit', but those early translucent G3 iBooks used an IBM screen which isn't as bright as the Samsungs used in the later G3 & G4 iBooks.
You want either IF183-026 which is the complete assembly, or IF150-052 which is just the LCD panel. Despite what instincts may tell you, fitting just the LCD panel, is a lot easier than replacing the whole top assembly.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The 12" LCD panel itself can be swapped between these Mac models:
- iBook G3 12"
- iBook G4 12"
- PowerBook G4 12"
Display assembly (plastics and cables) are often different and may not fit.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
robm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 914
