In cpc power supplying is not coming
In cpu power supplying is not working
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. 기존 질문에 이미지 추가하기
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 4
지난 30일: 5
전체 시간: 78
