주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My videocon ac showing e5 error
Some time My videocon ac showing e5 error
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
code L6 what's meaning
E5 error videocon ac and out door not start problem
@hasnainsha87010 did you check the answer?
댓글 달기
답변 1개
가장 유용한 답변
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Sanjeev Verma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 2,981
