My videocon ac showing e5 error
Some time My videocon ac showing e5 error
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 16
지난 30일: 54
전체 시간: 2,249
댓글 1개
code L6 what's meaning
Nabil Dekess 의
