주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Texas Instruments TI-84 Plus 계산기 지원.
Why is my screen frozen
When I turn on my calculator I none of the buttons I press work, the cursor is blinking on the screen but I can’t even turn the calculator off. I tried removing the batteries and charging it and that didn’t work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @leighacox
Try the following and check if it resolves the problem.
Remove the batteries and the back up battery from the calculator and then press and hold the ON button for a full 20 seconds and then release it.
Note: Remember the way that the back up battery was installed (+ve on top as seen on the battery itself) so that you reinsert it the correct way.
Reverse the procedure to reassemble the calculator and check if it turns on and works OK.
Here's the ifixit TI-84 Plus 분해 guide that may help. You don't have to go past Step.5
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Leigha Cox 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 80
전체 시간: 1,644
