주요 콘텐츠로 건너뛰기
모델 A1013, A1052, A1085, 또는 A1107 / 1440x900 스크린 해상도
20 질문 전체 보기
My laptop won't completely boot up.
I hit the power button and hard restarted my computer due to Safari freezing. The machine restarted, the apple came up in the white screen then goes to blue screen instead of Leopard background. Now all I can do is hit hard restart and it will do the same thing. Apple/white screen then to blue.
It will restart in safe mode but it won't do anything. Any thoughts other than logic board?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 4개
선택된 해법
You can first try starting in Safe Mode by holding down the Shift key. Next try booting from your installation disk by holding the "Option" key down. This will load the bootloader, where can choose the OSX installation disk to boot from. On about the second page you will see the drop down menu at the top of the screen. Go to Utilities - Disk utility and run the verify. If needed run the repair. Then try booting from the hard drive. If this fails reinstall the system.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hmm, it could be that some kernel is corrupted. Have you tried booting from the Leopard install disc?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Probably need to reset the PRAM.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Change hard drive on a aluminum 12" Powerbook G4 after replacing hard drive I tried installing 10.5 it asked for base system, put in 10.4 it asked for 10.3. put in a copy of 10.3 and nothing, it just flashes the question mark, file and the two faces what can I do.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chuck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,715
