주요 콘텐츠로 건너뛰기
9월 22일 출시된 Apple의 “더 작은” 2023년형 플래그십 스마트폰관련 수리, 분해 및 문제해결 정보입니다. 6.1인치 프로모션 OLED 디스플레이, 트리플 렌즈 후면 카메라 시스템, 그리고 5G가 특징입니다. iPhone 14 Pro의 후속 제품입니다.
Screen unresponsive after water damage
I dropped my phone in the water yesterday it was only submerged for a couple of seconds and it was working after that. However, when I tried charging it I got the liquid detection alert. I left it to dry overnight and charged it...now the screen is unresponsive. Is there anything I do myself to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @lisa85350
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit iPhone 15 Pro repair guide that may help.
Here is the Repairing iPhone Liquid Damage guide that may also be of some use.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Lisa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 36
전체 시간: 957
