주요 콘텐츠로 건너뛰기
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
14 질문 전체 보기
Dell Inspiron 15-3567 How to get inside
How do open this up ? I'm used to to getting inside desktop machines, not laptops.. But need to replace failing 1TB spinning HDD with SSD i'm gonna order.
Following this article: Dell Inspiron 15-3567 Fan Replacement - iFixit Repair Guide
Do you really need to remove optical drive ? as it looks like the screws in the image are just holding the metal tray itself, not securing the bottom case at all.
In any case i cannot get access to this part,.. I removed the battery, but them i don't know what to do in order to popup the optical drive, (if needed)
Removed the 8 screws from the bottom casing + screw relating to optical drive in the middle., and i'm guess all i need to really to is remove the screws underneath keyboard. but the only snag is optical drive,, can this be left alone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Looks like I had to remove optical drive, as it would potentially had issues opening up case after keyboard removal.
댓글 달기
답변 1개
가장 유용한 답변
Hi @tech198
Here's the service manual taken from this support webpage for the laptop.
Go to p.28 to view the procedure to remove/replace the HDD.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks... Took me a bit to while to disconnect keyboard ribbon connected to board, till i realized they put the orientation of the locking mechanism in reverse. It flips up in the opposite direction, not how you think it does
i.e the hinges of the lock are facing away from the ribbon, yet the lock flips in "from" the ribbon end
댓글 달기
답변을 추가하세요
na na 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 110
