주요 콘텐츠로 건너뛰기
HP에서 2020년 12월에 출시한 AMD 비즈니스 노트북인 HP EliteBook 845 G8 관련 수리 안내서, 분해 및 문제 해결 정보입니다. 모델 번호 1W3K7AV로 식별됩니다.
Can we have a general cleaning guide?
I just visited India. There is SO much dust there like I can't even describe it. I noticed more overheating so I assume it's dust filled into fans and stuff. Even the screen is icky. I was hoping for a cleaning guide (ex; fans, screen, between the bezels)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I guess....the answer is not necessary for being detailed. Anyone can do it.
All you need is a strong vacuum that can spin the fan. As for the bezel you, use it with great caution and avoid touching the screen.
댓글 달기
답변 1개
가장 유용한 답변
Hi @kalyabhatt
Here's the maintenance and service guide taken from this support webpage for the laptop.
It details the necessary steps to completely disassemble the laptop if that's what you want to do.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Generally the parts that need maintenance are the fans, which can collect dust (plus anywhere else where dust has entered the laptop), and the thermal paste, which is on top of the CPU and under the heat sink.
So, basically use the pre-existing OEM guides on iFixit for the following:
* fan: HP EliteBook 845 G8 팬 교체
* and heat sink: HP EliteBook 845 G8 방열판 교체
If you've watched Andy's dust cleaning videos from the Salem Techspert YouTube channel, then you've already have a good idea on how to clean dust from this laptop.
댓글 달기
답변을 추가하세요
Kalya Bhatt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 203
