My Triggers are stuck at %100
Hello friends. I have an issue on my xbox controller how can i solve this? I know the missing points are going to be soldered but they are just for rumble motors. My issue is not about vibration its about triggers stuck at %100. Let me add some pictures above.
์ข์ ์ง๋ฌธ์ ๋๊น?
๋๊ธ 2๊ฐ
Hello I donโt have any idea about resetting and firmware update. Can you explain me how can I do this.
I actually opened the inside to clean the controller and then that was the problem. Some solder connections broke, I can solder them again and there seems to be no physical problem with the hall sensor. In addition, when you bring a magnet closer to the hall sensor, there is no change in values, I do not have a voltmeter.
z0d0 ์
No, I didn't have the necessary tools for soldering, but I don't believe the solder points of the rumble engine are related to this, it's related to the solders.
z0d0 ์
