주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toshiba Satellite C650 시리즈 노트북에 대한 수리 안내서 및 지원.
Why the touchpad is not working
The touchpad is suddenly stopped
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Why is my mouse pad not working
의
@duanenelso51585 what do you consider the mouse pad to be? The computer really only has a touch pad.......
의
댓글 달기
답변 2개
가장 유용한 답변
You probably accidentally pressed a one of FN F1-F12 combination. A list of Toshiba FN keys that allow you to activate a range of features on your laptop listed below. The one you want is probably "Fn-F9":
  1. Press "Fn-Esc" to mute or unmute your computer's speakers.
  2. Press "Fn-F1" to lock your laptop. When you lock your laptop, only the user password you have set will allow anyone to access it.
  3. Press "Fn-F2" to display all power saving options available for your laptop. For example, you can turn off your optical drive to save battery life.
  4. Press "Fn-F3" to activate the Instant Standby mode. This mode powers down your computer except for the memory, allowing you to quickly turn on the computer the next time you need it. Instant Standby allows your computer to stay on for up to 30 hours.
  5. Press "Fn-F4" to activate the Hibernation mode. This mode is similar to Instant Standby except the power can last for 26 days; however, it takes longer to power on the computer.
  6. Press "Fn-F5" to cycle through your display options.
  7. Press "Fn-F6" to decrease the brightness of your monitor. Each time you press these keys, you decrease the brightness.
  8. Press "Fn-F7" to increase the brightness of your monitor. Each time you press these keys, you increase the brightness.
  9. Press "Fn-F8" to change your computer's wireless connection from Wi-Fi to Bluetooth and back again.
  10. Press "Fn-F9" to disable the mouse touchpad. Press the buttons again to enable it.
  11. Press "Fn-F10" to disable the arrow pad. Press the buttons again to enable it.
  12. Press "Fn-F11" together to disable the mouse number pad. Press the buttons again to enable it.
  13. Press "Fn-F12" together to zoom in your screen. Press the buttons again to zoom out.
  14. Press "Fn-Spacebar" to change the resolution of your monitor. Each time you press these buttons, the resolution changes.
I hope that helps.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@beletetenaw you are not telling us what you have checked and if this just happened all of a sudden or if anything preceded this.
first check to make sure that the Touchpad is enabled. To re-enable your touchpad:
On your laptop keyboard, press the Fn key and the F9 key at the same time.
Now check to see if it is enabled.
If that does not work you want to make sure that you have the proper driver. Since we don't know which OS you have (Windows?) it's difficult to tell you which driver you have to get. Definitely update the driver according to your OS.
Now, if none of that works, you may just have a bad touch pad. If so, time to replace it. Since iFixit doesn't yet have a guide for that, use something like this video
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Belete Tenaw 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 32
전체 시간: 725
