주요 콘텐츠로 건너뛰기
Repair information and troubleshooting help for the Acer Aspire ES1-111 laptop.
12 질문 전체 보기
Water went inside my laptop and display is not working
Water went inside my laptop nd display is not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
The first step in any water damage is to open the device and disconnect any power, including the battery, this will prevent corrosion and further damage,
Here Is a YouTube video demonstrating this process: https://www.youtube.com/watch?v=AOdhsWA-...
But typically, you will want to follow these steps:
  1. ensure the device is powered off
  2. remove all screws on the bottom of the device
  3. try to gently pry the bottom cover off the device
  4. look for the battery (large black rectangle)
    1. disconnect any cables or connectors, leading to the battery.
    2. remove screws holding the battery in place
  5. then fully remove the battery
once you have removed the battery, you can then inspect parts of the laptop for any water damage.
After that it is dependent on what has been damaged, but these steps will ensure that the damage from water is minimized
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Saakshi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 86
