주요 콘텐츠로 건너뛰기
Olympus 디지털 카메라 수리 안내서 및 지원.
Why cant I go into picture taking mode (stylus-7030)
ok so I gave my brother my newly gotten Olympus and when he got it, he dropped it. after that I didn't know if it had broken or not, so I just put it on my desk. after a month I started actually looking at it and the mettle on the lens was bent and it would not close. I tried turning it on when I was done charging it and it would only turn on when I plugged it in. After that it would only be on the library mode.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@inku46980 that is caused by the camera trying to either extend or retract the lens. Since it is bend, it can't do that and it turns off. Try the suggestions from this site If those don't work, you need to consider replacing the lens.
There are no guides for this as of yet. I would suggest that you look through the devices on here Olympus Camera and check which one "sort of" looks like yours" Luckily, these are all very similar in the way they come apart. You just have to work slow and be careful in removing parts.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thank you very much for this i will look into replacing the lens and if i have to i will make a guide thank you
댓글 달기
답변을 추가하세요
inku 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 33
