주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
14인치 HD WLED 디스플레이, Intel-3 프로세서, Windows 8을 탑재한 경량 노트북입니다. 2013년 말에 출시되었으며, 모델 번호 Latitude 3440(P37G/P28F)으로 식별할 수 있습니다.
How do I replace the Keyboard
I opened up the laptop and took out the motherboard which had a metal plate under it with plastic seemingly melted off to adhere this plate to the chassis. There seems to be no way to replace the keyboard unless i scratched all of the 20+ melted standoffs off and took this metal plate out. I am not sure what modell i have exactly but i know that the keyboard can't be removed from the other side since the top part of the chassis is one solid piece of plastic.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@chestnutecho that is correct. your keyboard is most likely considered part of the palmrest / upper cover. You did not tell us your exacty computer model but picked the 3440. Use this Dell Latitude 3440 Service Manual
Of course, you can always try and remove all of those plastic rivets, then pull the keyboard off. Now, the tricky part would be to attach a new one. You will need to find screws short enough, so as to not come out on the top of your case, while you screw those into the leftover plastic nubs that were the original rivets. It's most likely easier top find a used top case with keyboard and to replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ChestnutEcho 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 33
전체 시간: 937
