주요 콘텐츠로 건너뛰기
iHome iPL8 is an FM stereo alarm clock radio for iPod and iPhone. It serves as a lightning connector, FM stereo radio, speaker, charger, and alarm clock.
Diameter of dc female jack pin?
Just need to know the diameter of the female dc jack
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @kurtnorgren
I don't know the answer but if you don't get a more relevant answer, take the clock's AC/DC power adapter to an electronics spare parts store and then check what DC socket it fits into.
The most common plugs/sockets used that are very similar in barrel/centre pin size are a D5 size (5.5mm x 2.1mm) and a D6 size (5.5mm x 2.5mm). There's also a D4 (5.5mm x 1.7mm) as well, just to confuse the issue. There are others but they are noticeably different in their diameter than the previous ones mentioned
It is hard to visually tell the difference between a D5 and D6 plug and also mechanically as well.
There is a test however that helps to determine which is the size. A 5.5 x 2.1mm plug will fit into a 5.5 x 2.5 socket but the centre pin will be a loose fit i.e. plug's centre pin is 0.4mm smaller than the centre connector ring in the socket and there may be intermittent no power problems. A 5.5 x 2.5 plug will not fit into a 5.5.x 2.1 socket i.e. plug's centre pin is 0.4mm too big
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kurt Norgren 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 29
