Flap stays open while AC is off
Both of my Daikin air conditioners have recently developed a problem where the air flaps remain open even when the units are completely turned off. Does anyone know how to fix this issue?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hi @tlblkrn
Unfortunately I cannot even find a user manual for the model number you posted let alone a service manual or parts list for it.
The best that I can advise is try a power reset and check if they perform correctly.
Turn off the units if they are on and disconnect the power to the units i.e. remove the designated fuses or trip the designated breakers for the air con units in the house power box, for 5 minutes and then restore the power to the units and check.
The image below is what Daiken suggests but presumably you've already tried this.
(click on image)
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 11
지난 30일: 29
전체 시간: 138
댓글 2개
Hi @tlblkrn
What are the model numbers of the air con units?
jayeff 의
@jayeff Hello, Both of them are of Daikin MODEL: FTL18TV16T2D
Akib 의
