주요 콘텐츠로 건너뛰기
Acer Aspire 5738Z 15.6 inch Laptop, Intel Pentium Dual Core Mobile Processor T4200 2.0 GHz, 3 GB RAM, 250 GB HDD.
11 질문 전체 보기
Why my charging cable is not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi,
You’re description is very vague, however if you’re describing the cable then you need to use a multimeter to check if there is voltage at the cable end.
If you have voltage at the cable then you could do a reset (look up reset no data loss for your device) to see if this resolves the problem.
If there is no voltage at the cable end then you should try another power outlet first - if you still have no voltage on the cable then either your cable is damaged or the plug pack no longer works and may need replacement.
If you have voltage at the cable end then your issue extends to a component part on the laptop - this could be anything from charging socket itself needing cleaning or has failed, to an charging system IC that is faulty.
If the onboard charging system is faulty then you may need to take the laptop to a repairer for assessment.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
RashadRafeeh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 3
전체 시간: 17
