주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
TI-83 Plus는 1999년에 TI-83의 업그레이드 버전으로 출시된 그래프 계산기입니다.
Top screen cable appears slightly disconnected
My TI-83+ recently ran into the infamous glitchy screen issue, and I after checking the bottom screen cable using a multimeter to the best of my abilities, I am pretty sure that the top cable is the problem. Upon closer inspection, it looks like the top cable is slightly disconnected on one side, see images:
이미지
이미지
(The lines of melted cable are from my poor attempt at solving the issue using a cheap soldering iron, under the assumption that the problem was with the adhesive.)
Is it possible that my screen problems are due to this slight misalignment if the screen cable, and if so, how do I solve the issue?
Edit: After further thought, I think only the black part, which I assume to be the adhesive is misaligned. My question still stands though.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
The black part is just tape. I believe it's just to protect the contacts but it's not integral to the ribbon cable.
Be extremely careful when removing the tape because it's still sticky enough to rip the ribbon cable away from the circuit board. I've personally made that mistake and ruined a perfectly good calculator. I'm not sure you can use isopropyl alcohol or a heat gun without damaging the ribbon cable further.
Unfortunately TI designed these to be so unrepairable that nobody has ever found a easy permanent solution, especially not for the fine ribbon cable. Typically the solution is to just solder wires in place of the ribbon cable.
There's a long standing topic for repairing the TI-83 Plus which goes into many of the repair attempts: https://www.cemetech.net/forum/viewtopic...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Aron Andrén 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 12
전체 시간: 205
