Clicking Sound from right Speaker
I recently have started hearing a clicking sound come from the right speaker. Few things before I go further, yes I have checked for loose plastic in the earcup or loose cables and have not found any. The issue occurs whether or not the headset is plugged in or off, hinting that maybe there is just a loose cable or part in the actual speaker. If you even slightly move the headset or slightly tap it with your finger, you can hear a click come from the speaker.
I have yet to attempt to actually get into the speaker housing unit as they quite intensely protect it with a glued casing. However, if anyone has any idea what this clicking could be caused by and I can fix it by getting into the speaker holding, then I will find a way. Thanks!
좋은 질문입니까?
