Can you change the storage on this laptop
The laptop Dell Chromebook 3100 2 in 1 I have needed new emmc. But can I also take the emmc out and after put a sd card with a os on it?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
@li2 the Dell Chromebook 3100 uses eMMC storage which is soldered to the motherboard and it is not replaceable.
이 답변이 도움이 되었나요?
I meant that can you take out the emmc and put a sd card in the slot with Linux on it
@li2 no. The eMMC is soldered on the board. It is an IC and not slotted.
Ik I have a soldering kit and could take it out
@li2 well, you could find the schematic for your logic board and determine to traces for the eMMC. then you need to find the circuit diagram for your SSD and create your SATA circuit for the SSD. Even if you can unsolder the old IC, your computers motherboard does not have the proper connections or firmware to use anything different.
If you want to try something different, try and find a larger eMMC IC and replace your existing one.
You could also use a sd card instead or will that not make it not boot up
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 63
