주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년에 출시된 Acer Predator Helios 300은 여러 모델 번호로 식별할 수 있습니다. 대부분의 안내서는 모든 모델에 적용됩니다.
Graphic ic problem motherboard dead
Motherboard dead because of Graphic ic heat not turning on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@rameshwarp48401 how do you know it is your Graphic ic (which is your GPU)? You really need to let us know what and how you have checked this. You are also not saying if anything has happened to the laptop prior to this. If so, you want to give us the model number for your motherboard. With that, we can try and find the schematics so we can possibly help you to check your motherboard.
By the limited description you have given us, I would expect this board to be a Compal LA-921P. Let us know the complete model number for your computer so we can verify the board.
You need to check and see if you have video signal on either the HDMI connector or the eDP connector. If you have no video on HDMI it could be an issue with the NVidia IC or the VRam. If you have no video output on either the HDMI or the eDP it is most like an issue with the GPU but you have to make sure you check the GPU power first. Here is the schematic for the LA E921P mother board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
if the motherboard is dead then there is very little that you can do unless you have an identical motherboard somehow
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rameshwar Pardeshi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 241
