My a button only works when I press down hard
Is there any way to fix it without getting a new motherboard
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Hi!
Yes there is a way to fix it without replacing the motherboard.
First you need to get the motherboard out, then you will notice that there is a "Conductive pad" for the A,B,X,Y buttons located on the motherboard. Replace that one for a new one and you are good to go!
While you are there, it's recommended to replace the rubbers as well!
Guide: Nintendo 3DS XL Motherboard Replacement (in Step 22 you see the conductive pad already).
Part: https://www.aliexpress.us/item/225183229...
If you need anything else, please let us know!
이 답변이 도움이 되었나요?
Thank you I also figure out a another method that doesn't require replacing it by cleaning it with isopropyl alcohol which I just used
Yes, it's possible to take out the conductive pad, clean the traces with isopropyl alcohol, then dry it again and put the conductive pad back on. This should also work! But for optimal performance and to make sure that it won't happen soon again, it's recommended to replace it. Good luck with the repair!
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 51
