주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerMac G5는 Apple Corporation에서 2003년에 처음 제조한 데스크톱 컴퓨터입니다. 이 안내서는 2004년 Apple PowerMac G5 모델 번호 A1047 EMC 2061의 수리 과정을 검토합니다. 2006년에 먼저 개발자에게 그 후 소비자에게 Intel 스위치의 일환으로 판매가 중단되었습니다.
Cannot connect (mount) as server for MacBook Pro (new)
We have had a lot of trouble mounting servers between my desktop and laptop computers. Originally we had no problem at all. We could mount and do screen sharing at will. Later, we could not mount the desktop on the laptop. Now we cannot mount either on the other - tho can always see listed in the finder.
I get the following Msg:
The Finder cannot complete the operation because some data in "afp://10.0.1.4/" could not be read or written.
(Error code -36)
Of course I have been over the sharing settings many times.
Anyone have any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
How are you connected?
Sorry folks - I did not realize the the 2 machines would not appear inside my msg. One is a Mac Pro G5, other is a new MBP - All running Leopard: 10.5.8.
Connect via Airport. G5 is wired.
Again, I have triple checked the System Pref settings a dozen times. (tho this still does not preclude the problem being totally obvious.)
Like I said - it all used to work just fine.
댓글 달기
답변 4개
선택된 해법
Well - the system does not let you answer your own question so I had to make a new account.
Answer:
I called Apple Support. WOW that was easy!! I can't believe how easy. Of course I was going to have to pay since the machine is so old (6 years), but since I had upgraded the OS to Leopard, it was FREE!
- First call:
They said run "Fix Permissions" from the Disk Utility app. Then in Sys Prefs>Sharing turn OFF all sharing - do a restart - then turn them back on.
This was a good idea but did not work.
- Second call:
So I went back online and got an immediate slot - no waiting!
Solution:
SysPrefs>Security: Firewall tab:
There are 3 Options:
- Allow all incoming connections
- Allow only essential services
- Set access for specific services and applications.
The problem is that the list box is visible even when #2 is selected so it looks like the items are available. But they are not.
So I set to option #3 and was able to connect.
Not sure when my machine got changed, the other was probably changed at wife's work.
Hope this can help others.
BTW - Screen Sharing is awesome. Allows me to do a lot of compute intensive jobs on the faster machine while still on my main old G5.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
You should be able to answer your own question; the site just warns you about it before you submit. Also, thanks for posting your solution!
댓글 달기
Do each of these computers have assigned Static IP Address's? it not 10.0.1.4 may not be the computer you think it is..
if you don't like the idea of static, the next best thing would be to setup a DHCP reservation in your router. that way the router always assigns the correct IP address based on MAC address.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Can you make this easier to understand for a layman?
NO - I did check the IP first. That - of course - was trying to connect via the Finder "Connect to..." command. But if I try to connect by clicking on a Finder Window Sidebar (i.e. the icon for the other computer) then I get even less feedback - only "Failed."
But thanks for the idea.
Are they Both Macs?
Well - I finally got off my duff and put in a call to Apple on it. It has been a pain for a while - but never got up the energy to deal with it :)
Thanks to you all- now I have.
댓글 달기
This page will explain to you how to fix your problem.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
He wouldn't be using AFP if it was a windows computer.. or perhaps thats the issue?
Thanks again - but did not.
That was for connecting to a Windows server with SMB. Mine was an attempted AFP connection.
Both are Macs - used to be able to connect no prob, even screen share. NOw nothing.
My bad for not catching that detail, but it's the same error message so it'd be a similar cause. Have you by any chance changed the password on the computer?
댓글 달기
I'm just a regular computer user who doesn't know the difference between AFP and SMB. I usually connected to a shared network at work through AFP. However, I recently couldn't connect to the network and got error code 36. BUT when I tried changing from AFP to SMB, I was enable to connect to my network once again Yay!!!....just so you know....hope this helps
........POP.........
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jmmx 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 3,725
