주요 콘텐츠로 건너뛰기
2012년부터 계속되는 MacBook Pro 15" 레티나 디스플레이 노트북에 대한 수리 정보 및 안내서.
20 질문 전체 보기
2015 MBP 15" Logic Board connectors are slightly different why?
Hello all,
I received a donor logic board from my frieds Mid 2015 15" MBP. Both boards are (IG) compatible. After removing the old board, I replaced it with the donor board, and everything fits perfectly. However, there is a small issue with the trackpad connector and the card reader board flex cable connector.
Old board Trackpad connector is small and the Card reader connector is big
Old board Trackpad connector is Big and the Card reader connector is small
Both configuration are identical. i7 | 2.2Ghz | 16GB | Intel irish pro graphic
I'm really confused right now, and I need to figure this out. Hoping for some help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
@itsmeapple can you give us the 820-xxxx numbers on your boards? Let's see what we got going on here.
@oldturkey03 Hi, 820-00138-A this is the donor board number. my original board has a slightly different number 820-3662-A
Thank you
댓글 달기
답변 1개
선택된 해법
@itsmeapple logic board number for 820-3662-A relates to a MacBook Pro 15" A1398 Late 2013/2014. Logic board number 820-00138-A for a MacBook Pro 15" A1398 2015 (IG) I just verified with the schematics that these connectors are different. Unless you replace the trackpad etc. as well, you can't connect those components to your replacement board.
이 답변이 도움이 되었나요?
점수 2
댓글 9개:
Hello @oldturkey03
Thank you so much for your reply. What's strange is that my old board is showing that it’s a Mid 2015 15" MBP."
Please check the About This Mac. https://ibb.co/SQ29pnc
This is really confusing to me.
@itsmeapple I totally understand your confusion and I am with you on that. All I can say is that I exclusively go by the logic board numbers and compare the connectors, schematic or whatever the current issue maybe. In the case of your boards, the connectors are definitely different.
Thank you for understanding :) @oldturkey03 So what if i get the 2015 Trackpad and swap it? will it sit correctly and function?
U have mentioned this above but i just want to make sure if this is possible?
Thank you so very much.
@itsmeapple I never had to interchange those parts so I really can't answer this. I wonder if @livfe has done a switch like this.
That's alright i understand. let's hope someone will clarify this for us. :)
Appreciate your support @oldturkey03
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Itsmeapple 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 73
