주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-fi not working
The wifi is not working properly. It turns off and on by itself, does not connect to any Wi-Fi network and gives the response that there is a connection failure or connected without internet.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 6개:
[code]The wifi is not working properly. It turns off and on by itself, does not connect to any Wi-Fi network and gives the response that there is a connection failure or connected without internet.[/code]
의 공유
의 공유
samsung m12 wifi connect no network
의 공유
@hasan73750
See "If the WiFi stays on but still doesn't detect or connect to any networks", in the Answer below for what to do.
의 공유
samsung m12 wifi connect no network haw to solusan
의 공유
댓글 1개 더보기
댓글 달기
답변 1개
Hi @karolmorais
Try disabling the power saving setting and check if the WiFi stays on.
Go to Settings > Battery and device care > Battery > Power saving and disable it.
If the WiFi still turns on and off, try starting the phone in safe mode and check if the WiFi stays on and maintains a stable working connection.
If it does then a downloaded app (3rd party app) may be the cause of the problem. You will have to uninstall each downloaded app one by one and check the phone in normal mode between each uninstall to see if it works OK or not. When it does the last downloaded app that was uninstalled was the culprit.
If the WiFi stays on but still doesn't detect or connect to any networks, try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it connects and maintains a stable connection.
If it does there may be an antenna problem with the phone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Karol Morais 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 23
전체 시간: 675
