주요 콘텐츠로 건너뛰기
The HP Elitebook x360 1030 G2 is a 2-in-1 device serving both as a laptop and tablet. This page contains repair guides, maintenance and service information, and a troubleshooting manual related to the HP Elitebook x360 1030 G2. Battery model number: 1GY30PA
6 질문 전체 보기
CMOS Battery Location Inside HP EliteBook x360 1030 G2
Hello,
I have been searching online for videos of where the CMOS battery is located inside my HP EliteBook x360 1030 G2, but I have not been successful with any tangible search results.
Please, can you share a video of where the CMOS battery is located? I need to replace the CMOS battery ASAP!
I look forward to receiving a quick response from you. Thank you in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi Feyisetan,
One thing I give credit to HP for is that they make their service manuals available to the general public (i.e., us) so we have all the same information on repairing their computers that their computer technicians have.
In this case I've gone through the service guide for your laptop and have to conclude that there is no CMOS battery in your laptop. That's based on the fact that the service manual does not show any procedure for replacing one, unlike the 830 G6 guide that explicitly has a section on locating and removing the CMOS battery.
What I've been finding in the last few years is that it is not at all uncommon for manufacturers to leave out a CMOS battery and instead rely on the main battery to hold the RTC data instead of a dedicated separate battery. The RTC data requires an extremely small amount of power to maintain the setup data, so even a fully discharged battery will usually have enough residual charge to keep it alive. Of course, if the main battery fails or is removed, then you have to rely on the power cord to maintain the RTC data, which it will do until you unplug the power cord.
Given that, it would be odd for you to be having problems with your CMOS data unless your main battery is dead or defective. Are you having issues with it? Why exactly do you think you need to replace the CMOS battery?
Update (02/19/25)
So the laptop won't run at all unless it's plugged in to the wall adapter, right?
Despite the fact that the computer thinks the battery is fully charged, it seems like a pretty safe bet that your battery has died and almost certainly needs to be replaced. Here's the iFixit guide to replacing your battery.
HP Elitebook x360 1030 G2 Battery Replacement - iFixit Repair Guide
Outside of the need for a stupid T4 Torx screwdriver, it's a pretty easy job to replace your battery. The HP factory service manual is available on the device page for your laptop if you prefer.
That will fix both problems; that of not being able to run unplugged and the CMOS memory loss.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you for your detailed response, @dadinrokeit.
Well, the laptop goes off immediately, whenever there is power outage, even if the laptop battery is on 99%. Also, there’s an error message during startup when I try to restart — Real-Time Clock Power loss (005).
댓글 달기
It has an answer on I fix it here is the link.
HP EliteBook x360 830 G6 CMOS Battery Replacement - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 -1
댓글 2개:
Thank you for the response, @altonbell40070. Mine is HP EliteBook x360 1030 G2. Does the same procedure/method apply, please?
I can't find the location of the CMOS battery on my HP EliteBook x360 1030 G2, @altonbell40070. The layout architecture of the parts on the HP EliteBook x360 1030 G2 is different from that of the HP EliteBook x360 830 G6.
댓글 달기
답변을 추가하세요
Feyisetan Salau 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 54
전체 시간: 89
