주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 11월에 출시된 MacBook Pro 16''의 수리 안내서 및 분해 정보입니다. 모델 A2141, EMC 3347.
PROBLEM with screen image.
이미지
Today i had this surprise... the computer is working... if i connect a Hdmi to a tv or monitor.. it works fine.... has energy signal in the LCD but.. doesn´t appers any image in the Monitor ..is this a Flex or Tcon defect .. or i have to replace the intire Screen .. ???
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
It's hard to tell just from the grainy picture. Is the screen lighting up (glowing) if it is the backlight is working so that would remove the backlight flex issue.
Does the screens image change in any way moving the lid up and down or connecting or disconnecting the HDMI connection? If not then I would say the T-CON has an issue or the connecting to it. This is a different cable than the LCD cables which compose the image within the LCD. Do you have any damage within the Chin plate which sits just below the displays image area? That would be the LCD cables being damaged.
And lastly you didn't have a liquid spill or place the system down on a wet surface as the back hing area is quite open and wouldn't take much to get into the T-CON board.
In any case the display assembly would likely need replacing MacBook Pro 16" (2019) Display Assembly and here's the guide MacBook Pro 16" 2019 스크린 교체
Replace a display compatible with a model A2141 2019 16" MacBook Pro laptop. Includes the 3072 x 1920 LCD screen, display cover, bezel, FaceTime HD Camera, and clutch hinges. 이미지
제품
$444.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
orlando reis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 74
