주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2024년 4월에 출시된 Rakuten Kobo의 Libra Colour eReader 수리 및 분해 정보입니다. 모델 번호 N428 또는 N428B로 식별됩니다.
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
yes that is a broken display, it would need to be replaced.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks a lot! wish me luck replacing the screen by myself hahaha
의
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
의
댓글 달기
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Kobo Libra Colour (N428) 스크린 교체 and the Kobo Libra Colour 스크린 교체 guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Kobo Libra Colour N428 스크린 이미지
안내서
난이도:
조정
45 minutes - 1 hour
Kobo Libra Colour N428B Screen 이미지
안내서
Kobo Libra Colour (N428B) Screen Replacement
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ISDT 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 26
전체 시간: 181
