주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lancer는 Mitsubishi에서 제작한 4도어 세단 또는 5도어 해치백입니다. 표준 모델에는 1.5~2.4리터 크기의 가솔린 또는 디젤 엔진이 포함됩니다. 자동변속기 옵션으로는 자동, 수동, CVT가 있습니다.
How to change steering oil
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @preetsinghmann
What is the year of the vehicle?
의
Can you explain the problem is the steering stiff or make noise when you are at the end of the steering wheel's travel either way?
의
댓글 달기
답변 2개
가장 유용한 답변
@preetsinghmann you will need to flush the steering system and change the power steering fluid. Check this Mitsubishi Lancer Power Steering Components And Function. Since iFixit does not yet have a specific guide for that use something like this video to get it accomplished.
While you work on your car, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their Lancer. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you have a Mitsubishi Lancer EX 2013 with hydraulic power steering (most 1.6L and some 2.0L variants), you can change the power steering fluid yourself. If your car has Electric Power Steering (EPS), there is no steering fluid to replace.
Step 1: Confirm your steering type
Open the hood:
  • Hydraulic Power Steering: You'll see a small power steering fluid reservoir with a cap labeled "Power Steering."
  • Electric Power Steering (EPS): There is no reservoir.
Tools and materials
  • Mitsubishi-approved Power Steering Fluid or DEXRON III ATF (check your owner's manual or reservoir cap)
  • Turkey baster or fluid suction pump
  • Funnel
  • Drain pan
  • Pliers (for hose clamp, if doing a complete flush)
  • Clean rags
  1. Park the vehicle on a level surface and switch off the engine.
  2. Clean around the reservoir cap.
  3. Remove the cap.
  4. Use a suction pump or turkey baster to remove as much old fluid as possible.
  5. Refill with fresh fluid to the "MAX" mark.
  6. Start the engine.
  7. Turn the steering wheel slowly from full left lock to full right lock 10–15 times.
  8. Switch off the engine and repeat the suction/refill process 2–3 times until the fluid remains clean.
Method 2: Complete system flush
  1. Disconnect the return hose from the reservoir.
  2. Place the hose into a drain container.
  3. Plug the reservoir return port.
  4. Fill the reservoir with fresh fluid.
  5. Have an assistant start the engine for only a few seconds while you continue adding fresh fluid. Do not allow the reservoir to run dry.
  6. When clean fluid comes out of the return hose, stop the engine.
  7. Reconnect the hose securely.
  8. Fill the reservoir to the correct level.
  9. Start the engine and turn the steering wheel from lock to lock several times to bleed any air.
  10. Recheck the fluid level and top up if necessary.
Capacity
  • Total system capacity is approximately 0.8–1.0 liter.
  • For a complete flush, it's a good idea to have 2 liters of fresh fluid available.
After replacement
  • Check for leaks around the hoses and reservoir.
  • Ensure there is no whining noise from the power steering pump.
  • Verify the fluid level again after a short drive.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@dnckigyzh6hy9yk looks very much AI generated. While we do accept AI generated answer we do require the poster of that answer to be transparent and to declare that this is an AI generated answer.
의
댓글 달기
답변을 추가하세요
Preet Mann 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 45
전체 시간: 154
