주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Envy x360은 2014년부터 HP에서 제조한 노트북 제품군입니다. 터치스크린과 완전히 회전하는 디스플레이를 특징으로 합니다.
How much does it cost to replace just the screen?
My HP Envy x360 2-in-1 14-fc0xxx.
Has a little crack on the upper right hand side of the touch screen - barely a crack, however my laptop seems to think I am touching the screen so it keeps pressing random stuff making it hard to use my laptop.
Will I only need to replace the screen and how much would it cost?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @coop61311
The touch panel is integrated with the LCD panel as a complete module
Here's the maintenance and service guide for the laptop.
Go to p.46 (53 of 103 pdf) to view the procedure to remove/replace the display assembly.
On p.50 (57 of 103 pdf) it shows the HP part numbers for the two panels that are used with the model..
Search online using the part number only e.g. N91014-001 or N91013-001 to find suppliers that suit you best.
Usually the part number is located somewhere on the back of the LCD panel if you wish to verify which one you need.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@coop61311 iFixit doesn’t actually fix things for people. The site is a place for people to learn repair for themselves—the “i” in iFixit is you! For this repair, I’d start with the Maintenance And Service Guide HP ENVY X360 14 Inch 2 In 1 14 Fc0xxx. Check page 20 to determine which panel (different models) you will need to replace. Then use the part number to source the panel.
Use the step-by-step instruction (page46) from the same manual to replace the panel. The cost for the repair will be the price you pay for the panel.
If this task seems to be above your level of confidence, you will need to do an online search for a service that can replace it for you. The cost will of course be considerably higher.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
COOP 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 20
전체 시간: 62
