주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2001년에 처음 데뷔한(원래 모델명은 Airtrek) Mitsubishi Outlander는 4세대를 거치며 다재다능한 준중형에서 중형 크로스오버로 진화했습니다. 최신 세대(2021년 도입)는 Nissan Rogue와 공유하는 섀시를 사용하며, 181마력을 발휘하는 강력한 2.5L 4기통 엔진을 탑재하고 있습니다.
How to replace battery terminals
I need to know how to replace the positive and negative battery terminals posts
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi @tylerspears
Simple answer is that you can't.
The posts are integral part of the battery. They're not screwed into it.
If there's a problem with the posts themselves you need to replace the battery and dispose of it in a responsible manner
Why do you need to replace the posts?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@tylerspears, what year is your Outlander? The posts are usually part of the battery and cannot be replaced. You would need to replace the battery. What you can replace are the battery cables. The positive cable connects the battery to the starter motor and the car’s electrical system, while the negative cable connects the battery to a grounding point. Each cable attaches to the battery with a terminal end.
If those terminal ends need to be replaced, you remove the old ones (depending on how they are attached, you may have to cut them off) and then install new terminals. Again, the type of terminal you purchase determines how they attach to the battery cables. Most common replacements are of this type. Example only, not an endorsement of the seller.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tyler Spears 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 49
전체 시간: 214
