주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 장치는 ChiliPad 매트리스 패드를 순환하는 물을 냉각하거나 가열합니다. 모델: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit ChiliTechnology ChiliCube 분해도 guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks for the info. I will let you know how i progress.
의 공유
Fuse is good. So still looking.
의 공유
댓글 달기
답변을 추가하세요
Andrew Lovell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 35
전체 시간: 138
