주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HPL1710 Yellow Screen Problem
Meh IDK that Please I need your help maybe you need to put VGA well
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Can you try to explain more, we can't help you if you just say "Meh IDK that Please I need your help maybe you need to put VGA well"
의 공유
Hi @austuriface
Have you tried connecting a different , known, working vga cable to the monitor and checked if the display is OK?
Have you tried connecting the monitor to a different computer to check if the problem is the monitor or the first computer?
What have you tried?
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@austuriface this will depend on how yellow your screen is. If it looks like a smoked yellow, it will be the backlight. The HPL1710 uses CCFL backlight. Aging CCFL tubes will create a yellow screen. Replacing the CCFL tubes will remedy this.
If the screen is a bright yellow and adjusting the colors in your menu does not change it then the issue is most likely the main board. Having worked on this monitor model a lot, my money is on the CCFL tubes. It will help if you post some pictures of what your screen actually displays. That way we can be 100% certain.
Adding images to an existing question - iFixit Repair Guide
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
austuri face 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 27
전체 시간: 116
