주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7세대 Ford Fiesta는 이전 세대보다 한층 더 정교해진 인테리어와 첨단 기술에 집중했으며, 모델이 최종 단종되기 전 전동화 모델로의 전환을 시도했습니다. 주요 엔진 라인업은 1.0L EcoBoost 3기통 터보, 1.1L Ti-VCT 및 1.5L TDCi 디젤 엔진이었습니다. 고성능 지향 모델인 ST의 경우 197마력을 발휘하는 1.5L 3기통 EcoBoost 엔진이 탑재되었으며, 연비 향상을 위한 실린더 비활성화 기술이 적용되었습니다.
Reverse not functioning after replacing battery
I changed the car battery then the reverse function is not functioning. When drivibg forward there is noticeable not smooth when during shifting
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@zacsevilla it is possible that when you disconnected the battery the Transmission Control Module (TCM) may have lost its Keep Alive Memory (KAM). Erasing that memory means the computer has forgotten the precise bite points of the clutches and the exact positions of the internal shift forks, which frequently results in a locked-out reverse gear and shuddering forward shifts.
Start of by performing a Static Idle Relearn which will force the transmission to find the baseline positions. Start the engine and let it reach normal operating temperature. With your foot firmly pressing the brake pedal, shift from Park down into Reverse, Neutral, Drive, and Low/Sport. Leave the shifter in each position for exactly 5 seconds before moving to the next. Shift back up to Park in the same 5-second intervals. Turn the key off, wait 30 seconds, and restart to see if Reverse engages.
Now, if that did not work you will most likely need to run a TCM Adaptive Relearn via OBDII You will need to connect a diagnostic interface (like an ELM327 adapter) and use software like FORScan to run the "TCM Adaptive Learning" service procedure. That maybe one of those tasks where a professional shop will come in handy. The adapter as well as the software may not be that easy to come by and/or use.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Zac Sevilla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 48
전체 시간: 112
