주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Amazon의 5번째 Kindle Paperwhite(Kindle 기기 11세대의 일부)에 대한 수리, 분해 및 문제해결 정보입니다. 2021년 10월에 출시되었습니다. 모델 번호 M2L3EK 및 M2L4EK로 식별할 수 있습니다.
Stuck on low battery screen
I haven't used my kindle in a while and I let the battery completely die for several months (I know, not smart). I plugged it in last night and gave it a good 24 hour charge. The charging light turned green so I assume that means it is charged but the screen is stuck on the low battery screen and won't do anything else. I changed power cords, did hard resets, and even plugged it into my computer. With the hard reset the green light would blink twice, then the yellow light would blink 5 times, then it would go back to solid green. I assume the battery is just toast but does anyone have any other ideas before I try to replace?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@devinv10297 when a lithium-ion battery sits completely discharged for months drops the cell voltage below the safety threshold.. The battery's internal protection circuit will permanently disable the battery.
A solid green light on your device indicates that the motherboard has stopped supplying power. That does not mean your battery is fully charged ;) Try this: Connect your Kindle to a wall charger. Press and hold the power button for 60 seconds. If it does not turn on after doing this, remove the cover as shown in this teardown Kindle Paperwhite 11세대 분해 Unplug the battery from the motherboard. Press and hold the power button for 30 seconds to discharge the motherboard's capacitors. Connect the battery to the motherboard and plug the charger back in. If you continue to receive the blinking light error code after all of this, then your battery is dead.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Devin V 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 50
지난 30일: 50
전체 시간: 50
