Power and system damaged
Hello dear,my phone cannot enter to android it shows fix sign and after that did not respond power off completely,I checked the charging port and the battery,it ok
좋은 질문입니까?
좋은 질문입니까?
@mohamedrad56224 if the "fix sign" was a warning triangle with a wrench or phone icon on it then this is usually caused by a failed boot partition or the OS being corrupted. That should not have turned your phone off or prevent it from turning on, but you do have to check for a software issue first.
You would need to download the Sony Xperia Companion software and then choose the Software Repair option. Follow the instructions to connect your phone. To force your phone into flash mode, make you are holding down the Volume Down button when plugging the phone in. If it disconnects or goes off completely while the software repair is going on, then you have a hardware problem.
Let us know what you find out.
이 답변이 도움이 되었나요?
지난 24시간: 24
지난 7일: 24
지난 30일: 24
전체 시간: 24
I hope this helps.
Phone Won't Turn On
mura mura 의 공유
