Acer Aspire R7 Battery Replacement
Changing the Battery in an Acer Aspire R7 is a straightforward process if you find your computer has lost its ability to hold a charge.
The Aspire laptop battery enables the computer to work without having a power cord. It is a hardware component that is not externally accessible and requires a small amount of disassembly to replace.
The 4-cell replacement battery instructions are listed below in quick simple steps. Before using this guide make sure that the battery can no longer function in one of two ways, use a multimeter to test battery strength or check the settings on the laptop if possible.
If the battery is swollen be careful and proceed with caution and take appropriate precautions.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
Locate the battery ribbon connector
Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
다른 12명이 해당 안내서를 완성하였습니다.
댓글 6개
great instructions
hey how do you want då sel it for
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
Anthymoine - 답글
